RCMAN46
Jun 23, 2015Explorer
"and sometimes even different rear axle ratios. "
The rear axle ratio used should be determined by the torque/horsepower characteristics of the engine involved.
Also the transmission ratios will be included in determining the rear axle ratio.
Thus I would not expect nor should it be required that all of the trucks tested should have the same rear axle ratio. Each truck should use the ratio that best fits the above described issues and the job or hill that will be used.
With the Ram having lower rpm's for it's peak torque and horsepower I would expect the Ram would want a lower ratio rear end gear than the V8 diesels.
A 3.73 is a lower ratio than a 4.11 in case there is confusion about what was meant by a lower ratio rear end gear.
44,071 PostsLatest Activity: Aug 30, 2026
