RobertRyan
Jun 25, 2015Explorer
Been following the thread , standard definition of traction control. Take your pick
Brake force applied to one or more wheels
Reduction or suppression of spark sequence to one or more cylinders
Reduction of fuel supply to one or more cylinders
Closing the throttle, if the vehicle is fitted with drive by wire throttle
In turbocharged vehicles, a boost control solenoid is actuated to reduce boost and therefore engine power.
Typically, traction control systems share the electrohydraulic brake actuator (which does not use the conventional master cylinder and servo) and wheel speed sensors with ABS.
44,071 PostsLatest Activity: Aug 30, 2026
