ShinerBock
Jun 25, 2015Explorer
wilber1 wrote:
Well don't hurt yourself.....
I was going to just let it go with that last post with the pic, but since you want to continue to be an anus then I will oblige your request of how the torque management that everyone else is talking about in this thread is NOT the same as traction control.
First off, the torque management(or TM) that the rest of us in this thread were talking about is when the ECM cuts power to the engine between shifts so that the driveline will have less of a shock load on each shift and to increase their chances of not having to pay out during the warranty period(more on this later). The ECM(Engine Control Module) mapping or programming for this TM is separate from the mapping of the traction control(or TC), and THEY ARE NOT THE SAME. I am unsure if you know how engine/vehicle mapping works(or anything for that matter), but in its very basic form an ECMs mapping is pre-programmed commands for the engine/vehicle to respond given a certain set of criteria. For the TM that we are talking about, the ECM is programmed to cut power from the engine on every upshift and/or in lower rpms or gears.
Traction control(or TC) is not the same as the type of TM that we are talking about and actually has a separate ECM mapping for this. Traction control will also cut engine power(like the TM we are talking about will) along with applying the brakes of the vehicle to regain or gain traction. Just because they both cut engine power does NOT mean they are the same thing. They are used for different purposes and are completely separate from each other in their uses so don't get them confused. If you say torque management in a Ram, Ford, GM, or any other forum then they will know that you are referring to the ECM cutting power between shifts and NOT the traction control cutting power to gain traction. For some odd reason you want to link them as the same since the both limit torque output even though just about nobody else in the known world does (besides 1 Ausie), and even the engineers that know they are two different things. Although I think this has more to do with the fact that you do not like admitting when you are wrong and will use "attrition" so you don't have to admit it even though just about everyone else is proving you wrong.
44,071 PostsLatest Activity: Aug 30, 2026
