Cummins12V98 wrote:
mich800 wrote:
Me Again wrote:
ShinerBock wrote:
I am also pretty sure that any class 7/8 truck driver out there would disagree with the not needing extra gears when towing too. Go drive an Eaton 8 speed, 10 speed, and 13 speed up and down a few hills behind the same exact engine and you will see what a few extra gears will do.
I drove a class 8 tractor with a 13 speed roadranger. It had a 8V71 350 that's power band was from 1900-2200 RPM. Today's trucks have much wider power bands and fewer gears are needed and/or installed.
If RAM gets more gears a lot the reason will be keep up with the Jones! Why would someone buy 6 speed when the other two have 8, irregardless that they are V8's and the Cummins is a I-6.
I had to drive a Ryder box truck a week ago with the Cummins and Allison transmission. It was a six speed I believe. That thing was a dog and could not get out of its own way. More gears definitely would have made the drive more enjoyable.
Nope! It was a dog to protect the engine. De tuned.
That is not accurate and this old assumption needs to go away with the Dodo. Whether it is a 500 hp marine ISB or a 200 hp ISB in a school bus, the stock ECM has the ability to de-fuel to protect itself if need be no matter what peak power it is rated at. It is not like fixed mechanical fuel delivery systems of old. There are two main reasons Cummins de-tunes these engine and neither have to do with protecting the engine since it can already do that at various power levels.
The first reason is emissions. There different emissions certifications for each GVWR. Since US emissions is measured in grams per horsepower per hour, emissions play a major role in how much horsepower an engine is allowed to make along with the GVWR of the truck it is going in. In almost all cases, the emissions requirements force the manufacturer to tune these engine well below what they can reliably handle.
The second reason is because Cummins and most medium/heavy duty truck makes sell different power levels at a premium. An engine may have 5 different power levels for a certain GVWR and application with the only difference being engine calibration. Cummins and these truck manufacturers are able to up charge additional horsepower similar to how the up-charge HO outputs in the pickups.
Case in point, the trucks mich800 probably drove was either a Freightliner M2 or International MV. Both offer a Cummins ISB with several power ratings between 200 hp up to 325 hp. How much power you want depends on how much you want to pay. Being that Ryder is a rental company, they probably don't care to pay for the higher power and actually want you to take as long as possible with the truck so they can charge more. Another company that uses the exact same truck set up in their own fleet may want to pay for the additional power since time is money.
