TNrob
Aug 18, 2016Explorer
You have it set for heavy trailer? Mine works well on light trailer, at about 8.5. Pulling only 6000 or so pounds.
2016 Ram 2500 so i'm guessing the brake control is the same unit. Everything I've seen is that the issue is with heavier trailers, and simply not enough signal to the brakes. If I spot a suggested solution I'll toss it to you.
