minnow
Aug 18, 2016Explorer
To the OP, you are not the only one out there with this issue. From what I've read on some of the Ram forums, there is a software issue with some of the IBC controllers where the full 12 volts is not being sent to the trailer brakes. The issue is especially apparent to those towing heavier RV's. If after playing around with the Ram IBC settings and not getting the issue resolved, you may next need to check your trailer brakes. Check to see the brakes are adjusted properly and make sure there is no grease on the pads. Lippert, who makes most of the frames/axle assemblies have had issues with grease leaking past the seals. If all that checks out and changing the IBC settings hasn't improved things, I'd probably just go ahead and install the Prodigy. Last I've heard Ram is aware of the issue but has not released a fix.
