Perrysburg_Dodg
Aug 23, 2016Explorer
From what I gleaned from Ben's post I would bet that the problem is Ram is using the wrong size wire going from the controller to the trailer connector on the HD trucks. I know my EOH system I installed on my boat trailer requires a 12 AGW wire for their single axle system @ 30' max. For a dual axle a 10 AWG @ 30' max is required.
Couple that with the under rated wiring and piss poor connections the trailer manufacturers use and you will end up with issues. My 2004 Cougar's wiring was a joke. The connectors were the screw on wire nuts without any covering at all. and the wire looked to be only 14 AWG not 12 or 10!
Note, on my boat system the max length is the hyd brake line.
Don
Don
