Bedlam
Aug 24, 2016Moderator
Since aftermarket controllers work fine with the OEM wiring, you know it is something in the OEM controller hardware or software is causing these issues. I see the heavy electric profile as the most problematic and can use either of the other profiles with better braking, so I assume it is a programming error rather than controller hardware.
