otrfun
Aug 24, 2016Explorer II
Cummins12V98 wrote:I suppose that's true if you're mounting the brake controller in that immediate area (or not at all in Nichol's case). I chose to mount the BC in the bottom, center dash area (for reasons previously mentioned). It took all of 2 minutes to remove the driver's side lower dash panel which made routing the wires to the bottom, center dash area much easier. Probably should have mentioned that.Nicholsfamily05 wrote:I agree, nothing needs to be removed.
You don't even have to undo the screws and remove the plastic. Just look up and it's right there.
You can reach under unplug it and plug the new one in it took all of three minutes to do.
Like I said I'm not mounting mine permanently because I don't want holes as I'm hopeful they will have a patch for it.
