otrfun
Aug 24, 2016Explorer II
MudChucker wrote:You're welcome! That center console is a very nice option to have; unfortunately, it leaves you with very few mounting options beyond the lower dash area below the steering wheel. Suppose you could just temporarily lay the P3 inside one of the larger open console areas until you find a more permanent solution. Make sure it's secure and placed on the proper axis because any movement (or improper placement) could interfere with the proper operation of the inertia sensors while braking.
thanks for the details.
You are correct in your assumptions :)
Sadly, I have the big console so I'll have to figure out an installation location, I like to have access to the controller so under the column wouldn't be my first choice either.
