agesilaus wrote:
Not the jack, I may need the rod you use to lower the spare. With Ford you need a key like thingamajig you place on the end of the crank rod to engage the gear that lowers the tire. Does RAM need one. I need to search the track to see if these spare tire tools are in ir somewhere/ Where are those kept? Under the rear seat??
Back to the question of needing a "key" to lower the spare, not on mine. One of the 4 sections of rod that get connected have a 5 sided open end that engages the stud on the crank mechanism.
