jefe_4x4
Mar 19, 2014Explorer
Selecting an aftermarket bumper is a personal thing. The competing requirements are:
1. Cost. I was ready to get a buckstop when the sign-up list was passed around a few years ago but was not happy with the cost v. what you get.
2. Weight. I have had many specialized bumpers on 4x4'a i've owned including a Tomba Burro on my FJ55 which was painted orange and looked like that Oil Rig truck Bryan talked about. The problem was the weight on the front axle with the Warn 8K winch. Most of the aftermarket truck bumpers weigh from 300 to 400 pounds, or more, depending. For me that seemed too much for the Dana 60 front axle assy, which is rated at 5200 pounds. Add the 150 poiund Warn M15000 winch and you may be over the axle rating, especially when you consider the weight is leveraged way out beyond the front axle. When i change out the Dodge unit bearings (grrr!) to a higher rated bearing and hub assy, the defacto rating of that D-60 should improve. My winch comes with a carrier which is a lot of rather flimzy tubes, a very H.D. box the winch sits in, between a couple H.D. sheer plates for deflecting nocturnal bovine intruders. After hitting a bull elk at night in the Nevada desert with my Dodge I could see the need for a tougher front end. Not wanting to add too much to the weight i build my own upgrade which included sched. 4330 thick wall tubing welded in a maze to a Warn brush guard (which in reality won't deflect much) but is kind of a compromise. I also welded some ears on top to hold a larger 'radiator saver' in case a really big bovine comes over the top.I learned to do this from my jeeping dayz in case you get in a bad roll you can still drive away with water cooling.
3. Does it protect you? Is mine as strong as a ranch hand or a buckstop? No way. But it is some amount of front end protection without the weight penalty. Notice i clearanced the outer stock bumper to add a bit of approach angle for larger rocks and wash edges.
jefe
jefe
44,071 PostsLatest Activity: Aug 23, 2026
