- rexlionExplorerI don't try to remember which way is which. The easy way to tell is to turn the knob a couple clicks each way and compare how if feels to turn the knob. Stiffer setting = harder to turn. Softer setting = easier to turn.
- mellowExplorerWhile you are at it I would take them apart if you haven't already and grease the adjustment knob.
- AnEv942NomadA little white paint on the knob indicator goes a long ways in seeing where its at.
- jimh406Explorer IIIWhat cooldavidt said. I'll add I ran 6F, 9R loaded, and 3F, 1R unloaded on my SRW.
- Clockwise makes them stiffer (higher number = stiffer)
- cooldavidtExplorer9 is highest
It clicks for each number
Turn clockwise all the way to reach 9
If you want 5, the normal setting click counterclockwise 4 clicks
etc - Area13ExplorerPain in the rear. They are numbered if you crawl under your truck, use a magnafine glass and have lots of light. Solid shocks otherwise.
44,071 PostsLatest Activity: Aug 30, 2026
