Camper_Jeff___K's avatar
Oct 30, 2014
Rancho reminder. Performance report.
Tomorrow, October 31st, is the last day of Rancho's Shocktober 4 for 3 sale.
I ordered mine today at O'Reily's and was pleased to see that O'Reily's also had an additional $10.00 off per shock for $40.00 more off. To get the shocks, you must order by tomorrow and fill out, mail in the rebate coupon.
______________________________________________________________________
Review, 11/19/2014
The Rancho's installed very easily with the wheels on. Fronts, remove top nut, bolt is welded or part of attachment bracket. Lower bolt, remove the nut. the bolt end has a washer with a tab on it. Pay attention to the tab position. Sprayed liquid wrench (the type that loosens) on the bolts before starting. Rear shocks are easier. Loosen top nut, the bolt end is part of the bracket. Remove the nut from the bottom mount and pull out bolt. Be sure to install the rubber boots to the shocks to keep the dirt off them. Install is the reverse, quick and easy again.
The shocks are set at 5 now. The ride is comfortable and the shocks do an amazingly better job of controlling the rocking of the truck driving on bad dipping gravel roadway. On the pavement, the ride is smooth, no bounciness, very quick recovery of road induced suspension activity.
Rear Shocks, Old and New.
Front Shocks, Old and New.
I have to say I really the like the ride with the Rancho 9000's.
  • Raften wrote:
    My only problem with my Ranchos is adjusting the front ones. I have to jack up the front end in order to extend the springs enough to get enough space to turn the knob.
    Coil springs?
    Would there be room enough to fit a socket and extension in there?
    I know the knob isn't hex, but I'd bet a socket would fit on it.
  • I got mine in October and just sent in the rebate form. I hope to install before spring.
  • My only problem with my Ranchos is adjusting the front ones. I have to jack up the front end in order to extend the springs enough to get enough space to turn the knob.
  • I bought mine in August. My factory shocks were toast and basically non functional. I have the 9000s on two of my three trucks now... the '09 3500HD (camper hauler) and the '06 2500HD (part time daily driver, trailer tow rig)
    The beater farm truck, 84 K20 isn't worthy enough for new shocks. New springs would be a help though, to get rid of the add-a-leaf 2" lift. It rides like Ben Cartwright's buckboard Wagon.
  • Well joy of joys! I was getting ready to install my new Rancho 9000 shocks only to discover I had been delivered Rancho 5000s. It'll be a day or two before the correct items arrive.
