jerem0621
Jun 21, 2013Explorer II
Random Dually Tire Questions
1) Family budget is tight right now. The dually is a dedicated TV, not a DD. I have 2 tires that really need replaced and four that are at about 35% tread life. Thinking of replacing 2 tires that need it now and 2 a few months later, then the final 2 about 2 months later. (3 sets of 2 tires) Any reason NOT to spread the tire purchase out? At my rate of driving there may be a 5,000 mile discrepancy between set 1 and set 3.
2) Assuming its OK to buy the tires in 3 sets of 2.... should I always put the new tires on the steer axle?
3) Since I will be buying tires in 3 sets of 2 for the second set of two, should I put the good tires on the inside dually or on the outside?
4) I will probably be buying Firestone Transforce or Cooper tires...However, I am open to other brands, anyone have experience with Kumo, Hankook, or other brand tires on a dually? I have heard that the two best dually tires are Firestone Transforce and Michelin's. I really want GOOD tires.
5) I run Simulators on my factory steel wheels. I can check my front tire pressure without removing the simulators, and the outer Dually, but the inner dually is impossible. Can I run "valve extenders" successfully for the inner dually tire?
6) Should I have steel valve stems installed? Currently there is regular old rubber stems. Seem to be ok too.
Thanks!
Jeremiah
Thanks!
Jeremiah
