parker_rowe
Jan 10, 2019Explorer
ksss wrote:
I do agree with this point. These trucks are not substantially cheaper, and the mpg is not significantly better than the fullsize gas trucks (diesel not withstanding). You have to want one because the smaller dimensions fits your lifestyle and the price and mpg advantages (as small as they are) is just icing.
Back to the point of the Ranger performance up the Ike, the Toyota essential performed equally as well without being turbo charged. Either the Toyota is just an overperformer or the weight wasn't enough to challenge either of these trucks, but the way older Toyota was just as capable as the newly released Ranger. Not just in engine performance, but overall performance. I don't consider that to be a significant win for the Ranger. Will the Ranger be enough to grab significant marketshare from Toyota? I don't think so, they will grab some for sure, but I think they needed to set the bar higher to have significant impact on this segment.
I think this is the case. Both trucks are light enough with excess power to easily pull the 5K weight up the hill. The chassis in either can't handle enough weight to show wether or not the turbo engine has any advantage. Can't say wether it does or doesn't, but they both basically scored "perfect" runs maintaining the speed limit for the run.
That doesn't mean the ford is make less power than advertised, or that the toyota makes more.
It just means they both had enough power to maintain the speed limit up with hill the whole way.
44,056 PostsLatest Activity: May 04, 2014
