- ib516Explorer II
FishOnOne wrote:
ib516 wrote:
I wonder how people will react when they learn the front wheel and inner fender liner needs to be removed just to do an oil change on the Ranger? What a dumb design.
Cool little truck otherwise.
Can you provide a source to your comment?
From the links provided:
"A service procedure obtained by TTAC states that, after removing the left front wheel, a technician or owner must then remove an access panel secured by nine push-pin retainers. From there, one removes the filter with an end cap tool. To actually drain the oil, which of course you’ll accomplish before attacking that filter, you’ll first need to unbolt the power steering control module under body shield. Four bolts hold that on." - ksssExplorerI am not sure what the turbo in the Ranger really bought. The time up the hill was about even. I agreed with the Russian, I would have expected more from the 10 speed and more from the turbocharged engine at that elevation. Maybe there is some programing enhancements that need to be made, but with that kind output it is not going to hold up well at all to the GM twins. While I don't find the Taco masculine I just find it ugly, but the looks of the Ranger is "weak". Call it refined if it makes you feel better, but its weak. Especially when the 150 and SD trucks look so good, someone punted on the exterior design of Ranger. I was looking for this truck to honestly set the bar higher in the segment. It clearly doesn't do that. These guys give the win to the Ranger by the narrowest of margins, but the Taco is what about 7-8 model years old? I would say Ford aimed a little low with the Ranger. Ford guys will buy it, but anyone cross-shopping the others in the segment are not likely to be blown away by the new Ranger in comparison.
- LynnmorExplorer II
Maybe the Ford engineer was the same one that did the design of the Ford Escape battery tray. To replace the battery, step one is: remove windshield wipers and it gets worse from there. Me Again wrote:
Start here!
https://www.cnet.com/roadshow/news/2019-ford-ranger-oil-change-difficulty/
or go directly to this link.
https://www.thetruthaboutcars.com/2019/01/diyers-take-note-the-2019-ford-rangers-oil-change-procedure-contains-a-big-extra-step/
Time for Ron to figure a route from the top, which I use on my truck.
LOL...- Me_AgainExplorer III
Start here!
Time for Ron to figure a route from the top, which I use on my truck. ib516 wrote:
Can you provide a source to your comment?- ksssExplorer
That is a dumb design. That will be a $100 oil change if you pay to have it done. - ib516Explorer III wonder how people will react when they learn the front wheel and inner fender liner needs to be removed just to do an oil change on the Ranger? What a dumb design.
Cool little truck otherwise. - LwiddisExplorer IICompetition makes for better trucks. This Chevy guy is happy Ford is back with the Ranger.
- kw_00ExplorerThanks for the link, saw this last night and thought they both did well. It’s great to see another option in the mid sized truck game. It was interesting to see how the eco boost did but overall but it had similar times of the V6 taco. I hope they do a mid size shoot out with all the contenders, that would be interesting.
44,056 PostsLatest Activity: May 04, 2014
