itterref
Apr 11, 2023Explorer
Gentlemen, all the numbers are within limits except the 90 lbs over on the axle. That number will be reduced with 2 simple changes. The water tank will be empty reducing 200 lbs minimum and I will adjust the Hensley hitch and transfer more weight forward and to the trailer.
I will conduct another weigh in and report back. Do you all concur that it is acceptable to tow just below the limit?
44,056 PostsLatest Activity: Jan 12, 2020
