Re: 1st post and soon to be TC owner
The F350 is actually rated to carry more than the F450 even though some of the 450's components are heavier (there are a number of threads about this). The F450 is more of a towing machine than a hauling truck. The F350 in gas is rated to carry significantly more than either of the diesels and has more than enough power unless you are also going to tow heavy. (Big boat or small boat?)
I think it's fair to say if you plan on getting any of the heavier triple slides you should really consider jumping over the 450/4500 class and go right to the 550/5500 class. A number of people have done so here and been very happy.
With your height interior height is going to be an issue. I would really try and check them out. It's a long way for you but you will be spending a lot of money. You can carefully look at the specifications but they will not indicate low points. Hitting your head all of the time in the AC isn't going to be fun. The new, 2017, Arctic Foxes have gone to a "barrel" ceiling which may help you.
Slides do make a big difference in living space. If you are going to spend much time in them I would highly recommend one with a slide for the two of you.
No RepliesBe the first to reply
