panamacamper1 wrote:
I have the same issue with my 280. I am currently fighting with the dealer, cruiser and milder as to why this unit has 14 inch rims. I was told that my new axles will still say 3500 lbs on them but be the larger and stronger 5500lb axles that are needed. They said it is because the spindles will not change only the axles. Ever heard of such a thing?
Are they going to upgrade you to a 15 inch rim as well? If they do I'm going to try and push for that as well but I think if you upgrade to a 10 ply trailer tire it might be ok added with the bigger axels no?
