jadatis
May 04, 2023Explorer
Grit dog wrote:
^Thats TMI for the OP. He found the max psi rating on the tire. That’s good enough for him….
And you are overcomplicating it.
Then those pressure/loadcapacity lists for ST are also overcomplicating, and going even as low as 25 psi and no reserve and given per tire.
My list makes it allready a bitt less complicated, because given per axle and maximum reserve build in, so topicstarter dont need to do pre-calculations.
Wenn ever TS determined the axleloads acurately, it will most likely come to 65 psi, but then he knows its not a pressure determined in the blue.
Airstream TT's have as exeption to the rule, in general comfortable reserves in the tires the GAWR's and comfortable reserve in the GAWR'S to the GVWR.
Then often popped rivets when using the max of tire,
Most other brands have yust enaugh loadcapacity to law for the GAWR's.
So most TT brands need the max of tire or even more. Do then an upgrade of tires is a good idea.
44,059 PostsLatest Activity: Mar 18, 2026
