batavia02 wrote:
I am the op and no that wasn't what I was asking.I did appreciate all the comments, I figured some one would catch that sooner or later.I was asking, just to recap, can I,,use 3/4 ton or must it be a one ton duel .yes it will be diesel.and cc.5th wheel.will be 15500 max weight. 41is length. Columbus 385 bh.
I tow a very similar trailer. 41'+ Elkridge bunkhouse, GVWR 15500. I was towing this with a 2008 F350 CC SRW shortbox. I needed air bags, but it towed beautifully and straight. The only time I ever felt like I needed more truck was on mountain descents (didn't have exhaust brake) and in stiff cross winds.
I replaced the truck last fall with a '15 F350 DRW. I still needed air bags (I swear these springs are the same as my SRW). In nice weather on flat ground - I can't tell the difference between the 2 trucks. My SRW probably pulled straighter (less steering correction). Descending from a 10,000'+ elevation or cross-winds, I really notice the difference. More stability on banked corners and exhaust braking is much better. I climb the hill easier also, much more power, but the old one did it too. MPG are worse in the DRW, about 1-2mpg.
