afidel
Feb 09, 2023Explorer II
Before investing in a second AC I'd tear apart the ducts, look for missing tape, disconnected hose segments, etc. There's a very good chance your AC can keep things cool if it's properly installed, is just probably not installed correctly. A 20' cheap boroscope will allow you check to see if the vent is cut, kinked, or otherwise damaged.
In short you probably don't need to brute force your cooling with a second AC, you probably just need to use the cold your current AC can produce more efficiently by fixing the piss poor assembly job done at the RV factory.
44,056 PostsLatest Activity: Nov 19, 2013
