Limoges_Camper
Apr 06, 2015Explorer
Habs wrote:
I have read your post.. and I have an identical issue..The entire floor is warped,and forming mold... So ,, IN the end what did you do ?.
AND
Where was the leak for your trailor.. Was it from under the trailor.. or was it a toilet flood, or shower flood..
I bought the trailor used. and the owner told me there was a soft floor at the step just coming into trailor............... Well.. NOt so true.. THE entire floor is rotted.
Look forward to your return.
AeroCub 2002- UltraLight
Sure sounds like you got the same issues as I did (hopefully in past tense), here.
The leak happened because I believe they had a tire blowout that damaged the wheel well. From that point on, water was coming into the flooring because the wheel well no longer sealed it properly.
What did I end up doing? I thought I covered it well in this thread. As far as going after the previous guy: no, I didn't.
There is still some work to do now that Winter is over: I'm going to be upgrading the electronics, and possibly adding some shelves: the mods pages in this site are simply amazing! Tons of great ideas.
Oh, I forgot: I'm going to be replacing most of the outdoor rubber components as they are showing signs of U.V. and weather degradation (cracking). That will ensure that the trailer stays dry in those spots. I'm also going to take the A/C apart, and look at all the seams where the roofing meets with protrusions, and ensure they are all in good condition (or remedy, like I did the bathroom vent).
