Here's what we are ordering:
Standard Run Features:
Northwood Built, Independently Certified, Off-Road Chassis
Fully Welded, Thick-Wall Aluminum Frame Construction
One-Piece, Corona Treated, Continuous Fiberglass
Hot, Polyurethane Laminated, Multi-Layered Substrate Walls
High Density Block Foam Insulation
Wide-Body Floorplan
Universal Lube Axles
15" Aluminum Wheels / Tires & White Mod Spare
Shocks On All Four Wheels
Stabilizer Jacks
All-Conditions/Four Seasons Insulation With R-18 Ceiling
R-15 Reflective Foil Insulation in Roof
Heated Holding Tanks / Cathedral Arched Ceiling
Aerodynamic One Piece Front Cap w/BackRoad Armor
2 Independently Switched LED Hitch Lights
Easy Access LP Cover / Diamond Plate Bumper Wrap
LED Exterior Lighting
Roof Rack & Ladder
SLAM Door Latches on Pass Thru Storage Doors
12V Light in Storage Compartment
LPG Quick Connect & Black Water Flush System
Large Exterior Entry Grab Handle / Entry Door Friction Hinge
Exterior Shower / 2 Afox Logo Director's Chairs
Semi-Automatic Winterization/By-Pass System
6 Gal DSI Gas/Elect Quick Recovery Water Heater
13.5m BTU Air Conditioner w/Condensation-Resistant Ducting
Carefree Travel'R 12V Awning
Travel'R Awning Adj Pitch Hardware
TV Antenna
Outside Speakers/Battery Disconnect
Tinted Windows
Satellite Ready / Solar Ready
LED Interior Utility Lighting
Interior Command Center
Roller Bearing Drawer Glides
Fabric Night Shade Window Treatments
19" 110/12v LED TV & AM/FM/CD/DVD Player w/Bluetooth
Smoke, LPG & CO Leak Detectors
Booth Dinette
Charge Wizard Residential,
Large Fridge (6 Cu Ft) w/ Multiple Raised Panels
Kitchen Skylight w/ Shade
Fan Vent (Bedroom)
Porcelain, Foot-Pedal Toilet / Bath Skylight
Glass Shower Enclosure / Shower Pan
NW TruRest Queen Mattress w/ Bedspread
Built-In Laundry Chute
12-Volt Power Jack
These are options that we ordered:
Microwave Delete with Cabinet Door
Addit'l Fan Vent-Bathroom (Exhaust Only)
Thermal Pane Windows
Generator Ready w/11 m BTU AC (Del 13.5 AC)
2.5 Onan LP Generator
160 Watt Solar Panel
These are options that we did not order:
Battery Box Kit
15K Air Conditioner w/ Ducting
Addit'l Fan Vent-Kitchen(Cannot Have with AC)
Powered Scissor Jacks, Front and Rear
Storm Windows
Sit & Sleep Sofa
Bed Bedroom Carpet w/Pad
BBQ Grill w/ Bracket
