NinerBikes
Mar 01, 2019Explorer
T18skyguy wrote:
Thank you all, you guys are teaching me a lot. I am in Oregon, and the button on the pump said S15. Had never seen that before. I have a 2016 Duramax, so I better read the manual. My rig has only 3600 miles on it, and I have changed oil once, but not fuel filter. I better look into it. I need to find out how often the fuel filter needs changed. We got a foot of snow now. I can wait a bit. I don't drive it much right now.
S-15 is 15 ppm sulfur or less, otherwise known as Ultra Low Sulfur Diesel or ULSD. Been around, and mandated for years now, ever since Diesel Particulate filters, common rail diesels, Catalytic converters and Ad Blue NOX treatment has been around. Sulfur pollutes all those filters and emissions scrubbers, and contaminates and ruins them.
S-15 is regular old diesel 2 or D2 nowadays.
Bosch does not recommend anything more that B-5 or 5% biodiesel in any of their fuel injections diesel systems. As a lubricant agent, 1 to 2% blended in adds plenty of lubricity to lower the wear of your fuel injection system.
I have very strong opinions on running biodiesel made from waste vegetable oil or renderings or recycled Fatty Acid Methyl Esters based biodiesel through any diesel engine. It's simple.. Garbage IN, Garbage OUT. No way I am going to knowingly run garbage waste oil through a very, very expensive fuel injection system that's standard with these common rail diesel engines.
Beyond adding a 1 to 2% addition of biodiesel, for lubricity, if you are doing high turnover rates of your diesel fuel, I don't see any value added. It has about 7 to 8% less energy per gallon that regular ULSD. If you can avoid biodiesel, I would, no engine or fuel injection system has ever been white paper designed to run on biodiesel. All of them have been designed, since inception, to run on petroleum based D2.
44,027 PostsLatest Activity: Apr 19, 2019
