BillS
Mar 06, 2015Explorer
ChooChooMan74 wrote:
Unless a propane man comes on and corrects me, you won't be able to unless you have a way to pump the liquid propane from the tank into the portable cylinder. All you will get is vapor out the top of the tank.
Correct. If the large tank has a "wet" valve and hose that draws liquid propane from near the bottom of the large tank, the small tanks can be filled with liquid propane by slowly venting the vapor off the small tank. If no "wet" valve on the large tank, no liquid will be transferred, only vapor. Most residential type LP tanks draw only vapor from the top of the tank and are not equipped with a "wet" valve. Some farm tanks are equipped with a "wet" valve in order to fill LP gas fueled tractor fuel tanks.
When I returned a 250-gallon lease LP gas tank, our locally owned LP gas dealer gave me credit for the remaining fuel in the tank.:)
Bill
44,066 PostsLatest Activity: May 13, 2026
