cruthas
Jul 22, 2013Explorer
Reddog1 wrote:
My bet is it will be very simple when you find the problem. Finding it may not be so simple. :B
You have not commented on my suggestion of using an Ohm meter. This suggest to me you have not used one. I really encourage you to look into Ohm meters, they can be your best friend. The basic use will be of great value to you. If you have access to Harbor Freight, the meter is as cheap as $3 on sale. It also has a volt meter, AC and DC. A very valuable tool, even in the cheap (inexpensive) versions.
Luckily I have an ohm meter at home so I will definitely try it. Only used it on a motorcycle so it'll be interesting figuring it out on the camper.
44,027 PostsLatest Activity: Apr 19, 2019
