tmckenna
Jun 17, 2020Explorer
time2roll wrote:
Yes if you have an open slot you can pop in a breaker and have a separate converter circuit. Assuming you power the entire panel you can just switch the converter breaker off as needed.
If you have a 30 amp RV NEC only allows 5 branch circuits. So technically you are not to code. I have 7 so that my rarely used converter or tank heaters can remain off most of the time. Never an issue.
Yes lithium has advantages. Most answers are for a fairly tight budget.
1800 watts is a lot of solar.
I dont have an infinite budget, but Ive done a ton of research and I know that what I'm looking to do isnt cheap.
Also yes, 1800 watts of solar is quite a bit, but I dont plan on using the roof of my camper for anything so I figured its as good a use as any haha
44,055 PostsLatest Activity: Dec 23, 2025
