dixonceExplorerMay 28, 2017Correct TruckI am looking to purchase a Grand Design Momentum TH 376th. The GVWR is 20,000lbs. The truck I am looking to use for this is the 2017 F350 dually with the diesel. Do have enough truck once loaded with ...Show More
vonzoogExplorerJul 10, 2017Question ( mostly to RAM owners, but everyone else are welcome to join in). Looking at possibly a Momentum 376TH. Do you think my 2016 RAM DRW with a 68 RE transmission and 3.73 rears is adequate for this unit. 1st. Would I need air bags to keep everything level?2nd. Would I need to change out rear to 4.10 gears?Thanks in advance,
Related Content5th Wheel Alignment & Lippert Correct TrackTruckcorrect part number neededTruck warrantyCostco Has Motor Voltage Correction Devices
