Terryallan
Nov 23, 2021Explorer II
Grit dog wrote:Terryallan wrote:
It would be unsafe on the highway, not to mention it would unload the front axle and cause sway with out the WDH.
Where was I wrong? A WDH is absolutly needed for a TT with a tongue weight over 500lbs on a F150. Maybe it's not me that is ill informed. And in truth. I feel the same about your posts.
The part of your old quote above about unloading the front axle and causing sway is the ill-informed part.
Per the hitch rating, yes wdh is "required" (discounting the fact the hitch won't fail under significantly more than 500lbs, personal experience). Can't refute that if someone want's to "go by the numbers."
Unload front axle? If ALL of the tongue weight, weight bearing, unloaded the front axle, it would take 200lbs or less off the front axle. Insignificant.
But saying not using a wdh will cause sway is wholly false. Sway control on a wdh can/will control sway IF it happens.
And that's your opinion. A WDH returns lost weight to the steering axle, and so it returns steering control, and prevents sway. A TT that has a properly setup WDH will not sway, even without sway control. Sway control is only for those emergency events when you induce sway by dodging a road hazard, or accident. Sway control is not needed in normal driving.
However. A driver must take the time to setup the WDH properly.
44,029 PostsLatest Activity: Jan 28, 2025
