Considering replacing the old girl - 04 8.1 Yukon XL as her electrical gremlins and module failures are becoming increasingly frequent. Plan 1 had been max payload SCrew with max tow pkg but then saw...
The interesting thing is that the tow rating for the max payload 150 and the Yukon is the same, but the F150 has significantly higher payload. The real difference is the inherent weight of the TV. I wouldn't consider standard f150 for what I am hauling don't worry. Waiting for 2 max payload versions to come in so I can crawl around and really see the differences. Should say over 90% of the mileage will be unloaded. Tow 4-5 trips per year and usually less than 2 hour trips.
