LERD
Nov 29, 2020Explorer
librty02 wrote:
What does this mean?!?! In the tow guide right under the 150s ratings...
Maximum payload and towing capabilities are for properly equipped vehicles with required equipment and a 150-lb. driver and passengerand vary based on cargo, vehicle configuration, accessories, option content and number of passengers. See label on door jamb for carrying capacity of a specific vehicle. Horsepower, torque, payload and towing are independent attributes and may not be achieved
simultaneously. For additional information, see your Ford Dealer.
Does this mean 300lbs is kept off that tire and payload rating sticker for 2021?!?!
If you look at the slide in camper section of the F150, each vehicle configuration has it's payload number listed on the chart. But at the very front of that chart area, you will see what constitutes that determination. But you will also see that it doesn't assume how many people your hauling. So the final payload will be the number on the chart PLUS 150lbs for each and every seating position on the truck. That means an additional 900lbs for a bench seat truck.
44,055 PostsLatest Activity: Dec 23, 2025
