deserteagle56
Jan 22, 2023Explorer II
adamis wrote:
5. Getting back to the expense of strengthening the frame. Even if I spend $3000 to $5000 to have it done, I'm still way ahead of buying a new truck. The other thing is, my truck is only two wheel drive. Fine for California but my plan will be to start going to areas where there may be snow and ice and I don't want to be doing that in a 2 wheel drive truck. So the longterm plan is to take the truck to a 4x4 shop and have them do a 4x4 conversion on it and while they do that, they can add rigidity to the frame. Yeah, I know, it's extreme measures but even if I put $10k to $20k into this route, I'm still WAY ahead of a $70k to $90k new truck (and used trucks aren't all that much cheaper these days).
Methinks you would be money ahead to take your time and find a newer used 4x4 truck that's in great shape instead of converting the one you have to 4wd. I've been following conversion projects like this for some time and most end up spending a MINIMUM of $15,000, and that's doing the work themselves. Can't even imagine what a shop would charge to do the conversion. There's a lot more involved than just adding a front axle and a transfer case...little things like speedometer and odometer that will no longer work properly because a transfer case has been added.
44,068 PostsLatest Activity: Jun 14, 2026
