jefffoxsrExplorerApr 08, 2014HVAC problem.What is likely the problem when, for example, the driver's hvac zone won't put out heat and the passenger zone puts out heat? Thanks.
rickguExplorerApr 08, 2014I believe the plastic gears in the unit stripped out on mine causing the door to not operate. I could hear the door clunking trying to close.
Related ContentTroubleshoot fridge problem...HVAC - No Compressor runColeman Maxair HVACbraking problemOnan Problem
