PatrickFisherPr
Dec 15, 2015Explorer
I appreciate your responses.
Here is the furnace manual. The wiring diagram is on the last page. http://manuals.adventurerv.net/Suburban-Install_NT-12SE_NT-16SE_NT-20SE.pdf
The power going in to the furnace is a bit over 13 volts. The blower kicks on. It runs continuously without the gas valve opening or the ignition sparking.
After the blower runs the sail switch is closing. It is remaining closed.
I didn't mean the wire from the fail switch is hot in temperature. I meant it is live.
I think the issue is the contact arrangement on the board. From left to right they are as follows:
Number one is the red wire, +12V DC
Two and three have no wires
Four is the brown wire, which turns gas on
Five is the black wire, which goes down to the electrode
Six is the yellow wire, -12V DC
I just bought a wiring kit, model number 520840, hoping that will resolve my issue.
Any additional thoughts would be greatly appreciate. If someone can confirm the contacts that would be a massive help.
44,056 PostsLatest Activity: Jan 12, 2020
