bikerdib
Jul 16, 2014Explorer
I'm not sure about your truck but there has been a movement from the heavy weight steel C-channel frames of the past to lighter weight steel box section frames on newer trucks. The light weight steel wouldn't be the best place to weld a tie down IMO unless a backplate is first welded to the frame section. (I've done more steel fabrication than I can remember over the last 40 years or so). Any fabricator worth dealing with should easily be able to fab up a bolt on tiedown.
44,052 PostsLatest Activity: Oct 25, 2025
