After using it a few times I've found a few issues. When we got it home I noticed 2 of the lag bolts holding the slide out mechanism to the camper loose. I ended up putting a lag bolt up through the dump valve compartment to get rid of one of the lag bolts. The next issue was the passenger side trim on the bottom was coming off so I had to reattach it. Another issue was the remote for the jacks didn't work very well. I took off the cover over the power center and found that the antenna for the remote was just coiled up on the control board. I unwrapped it, stretched it out and secured it to the 12v wires. Hopefully this will take care of some of the remote issues.
