wibigfoot
Mar 26, 2015Explorer
myredracer wrote:wibigfoot wrote:
wow thanks everyone for the feedback. I know Jayco brags about their frames and was surprised to learn their frames were Lippert as well. I didn't know that.
It turns out Apex frames are designed for each unit. They are not stacked and built to Apex specs.
I guess there is no getting away from Lippert since most mfg use them.
Lippert is not used on all Jayco TTs. Jay Feather and Whitehawk models have a Norco frame that Jayco calls Nextgen and it's made by BAL/Norco not Lippert. Jayco info. here. This is what is basically the BAL Ultraframe and it has no welding on it whatsoever and uses huck bolts to fasten pieces together. It's a very interesting looking frame.
Thanks for pointing that out. Now that you have I do recall reading that. I'm sure you know how it is that you look at so many models you start to forget things from model to model.
44,026 PostsLatest Activity: Mar 03, 2025
