DallasSteve's avatar
DallasSteve
Nomad II
Nov 19, 2023
Solved
My Travel Trailer Fell Down
I was putting yellow blocks under my travel trailer wheels on one side to level it.  My lot is not paved, not gravel, just dirt and grass.  I did the job and it was great.  It was level.  Then I was ...
  • valhalla360's avatar
    Nov 20, 2023
    Raise it up as much as you can then use jack stands or wood cribbing to hold the a-frame. Raise the jack and put more cribbing under the jack, so you can raise it further.
    Honestly, I don't like using lots of blocks under the tires or jack. I typically limit the tires to a couple of 2x? thickness before looking at other sites. I do have a wood stand I made for the jack but it's about 1ftx1ft, so unlikely to slip. It's made of 2x4s, so plenty strong.
    If it's your permanent storage site, I would try to level it, so you don't need any blocks.
