JrStafford
Aug 12, 2020Explorer
mkirsch wrote:
I think you're barking up the wrong tree. Your AC should run until it reaches the preset temperature as determined by the thermostat knob, then cycle on and off as the temperature rises and falls.
It should not be running that long, freezing you out, then freezing up. Initial run in a hot camper may be a little longer but once cooled down it should not run more than half an hour at a time unless it is severely hot and can't keep up. Since it is freezing you out, it obviously is not severely hot, and has no issues keeping up.
The most obvious cause is your thermostat is not working. However, is it possible that you simply are not familiar with how an old analog AC unit works? As you turn the thermostat knob, the wider the line, the colder the setting.
When I set my AC, I simply turn it to max cold, let it run until the camper gets to the desired temperature, and then turn the knob back until the compressor shuts off. Then it will cycle on and off to maintain that temperature.
Hmmmmm.....There's not a thermostat, just the knob that adjusts cooler and warmer, maybe I need to adjust it down? I know it works, if you set it lower, the AC cycles on and off. It's definitely been hot here, I went into the camper yesterday in the middle of the day and the inside temp was 104 lol. Running the AC on high for 30 minutes cooled it right down, but it just keeps getting colder and colder until the temp in the camper is about 63. I will try the knob to see if it helps to stop the freezing up by cycling on and off.
44,059 PostsLatest Activity: Mar 18, 2026
