GeoffW90
Apr 16, 2018Explorer
canuckystan wrote:
Just wondering if I even need a WDH, dealer says no....GeoffW90 wrote:
Congrats on the new rig! If all you plan on using the generator for is charging the battery, I would go for the solar panels to be honest.
The generator will use a trickle charger to charge the batteries and will take a fairly long time. I believe it was in the realm of 3-4 hours if they were about half. 2 ea 6V batteries will do you for a weekend with moderate use in my experience.
I only use a 100 w solar panel and my generators run when we use appliances and what not, so that would be the only reason to use a genny. Just my thoughts.
Good luck!
Here is what I would do... try it without, worst case is you will need to purchase one. Any (well a good dealer) would have stock and be able to set you up. The trailer isn't too heavy IMHO, I would go without. I had a small trailer before this one with a Ram 1500. Roughly the same dims and weights as yours, I just used a height adjustable hitch that I picked up at Canadian Tire.
-GW
44,059 PostsLatest Activity: Mar 18, 2026
