ADC0731
Aug 17, 2015Explorer
I have basically the same truck, but 4x2.
The 1500HD quadrasteer is not well understood, it was designed for trailering and carrying. The rear wheel track is 5 inches or so wider than the standard truck and has load-adjustable rear shocks. I carry a 2600 lb loaded camper with no issues over 20,000 miles so far. I do have stableloads installed and highly recommend them. You will be amazed at how well your truck handles in 4-wheel steer mode with a camper on.
My only concern for you would be the added weight of a boat but you should be fine with any camper in the 2000 lb range.
p.s. My scale weight with 2 people and loaded for long-distance travel is 8550 lbs.
44,027 PostsLatest Activity: Apr 19, 2019
