Joe417
Apr 09, 2023Explorer
I've changed several of the converters over the years. I would personally only change the converter at the bottom section. Would require only a few wire changes. But you can change the whole power center.
There are several good converters that are multistage charging which will protect the battery better. I like the Progressive Dynamics PD9100 with the charge wizard. It has maintained two 122Ah lead acid batteries for 12 years. Batteries are just a little weak now. But that fantastic for lead acid walmart batteries.
If you have a location it will fit somewhere, all required is to run a bit of wiring to get it back working.
Good luck.
Good luck.
44,027 PostsLatest Activity: Apr 19, 2019
