Re: Not getting propane in RV -- bad regulator?
Has the propane worked just fine, in the last two months of ownership? You didn't mention the obvious, that there is propane in the tanks.
Did you have the tanks shut off, and then open them too fast? You could try closing the valves, and then reopen them very slowly.
It could be the regulator, but not likely, if no problems in the past.
Jerry
Replies have been turned off for this discussion
