ervinjason
May 02, 2022Explorer
ssthrd wrote:
I'm looking at the slide in camper above which is 108" in the bed of my 80" box. The advertised dry weight is 1675lbs, so probably 2500lbs or so on the road. I figure that with my wife and my dog plus whatever else we may have inside the truck will be maybe another 500lbs, so total weight probably in the 3,000lb area. The payload sticker on the door is 3470lbs, so I should be good to go for total weight.
My question:
I understand that standard practice for manufacturers is to mark the center of gravity at the longitudinal center of the portion of the camper in the truck bed (108"/2=54") Since the center of my box is 80"/2=40', that puts the camper CG 14" behind the axle. The manufacturers method for finding CG seems flawed since they ignore the 6' of sleeper which is over the truck cab.
Has anyone put a similar sized camper in a short box truck and had any wonky experiences with it?
I'm on the fence about it but the price is definitely right.
COG is not simply the length in the bed and beyond halved. Your understanding is incorrect. I would suggest you to contact the manufacturer.
44,060 PostsLatest Activity: Mar 28, 2026
