sbryan
Oct 21, 2019Explorer II
Re: prevent fresh water from freezing
If your fresh water tank is inside the camper shell and the camper is reasonably well insulated you shouldn't have an issue as long as your water lines are also inside the camper shell. We have camped in zero weather and never had an issue. If you heat at night while occupied you should be good during the day.
