lwbfl
Jul 03, 2022Explorer
pbeverly wrote:
What do you mean about "fold away". In the Lippert site I see pull out and fold down.
If the stairs have feet on the ground you need to adjust them to be shorter. The first thing I do when setting up is get my stairs set properly and testing the door. Sometimes there is not a perfect leg adjustment setting for the situation so I carry some different sizes of wood to shim them so they are rock steady before using them. If the legs are too short and not shimmed you can bend the step area where they are attached to the camper where the door goes over it when closing. If you do bend it you can close the door and gently bend it back.
Yes!
44,067 PostsLatest Activity: Jun 03, 2026
