annakwlee
Jul 15, 2014Explorer
I did a little search on the web and found this from Forest River's Website Q&A section:
Q-I noticed some air bubbles in my rubber roof, will they cause any problem?
Not at all! During the manufacturing process, the glue used to secure the rubber to the plywood underpayment goes through a “curing” process. In some instances, the glue continues to “cure” after the rubber is in place and the gas causes an air pocket. Typically, they will never get any larger and do not pose any threat for leakage or structural problems. If your unit has an air bubble that is making you uncomfortable, have your local Forest River dealer check it for your piece of mind.
Q-What should I use to coat my rubber roof?
Nothing! The only maintenance to the rubber roof itself is washing it a few times a year. Most standard household detergents are appropriate (avoid petroleum based solvents, harsh abrasives or citrus based products) to clean with warm water. Keep debris cleared to help avoid stains.
Note: While the rubber itself is relatively maintenance free, any sealed openings in the roof do require periodic inspections & resealing. Please review the Owner’s Manual for more information on the Care & Maintenance of your RV.
44,030 PostsLatest Activity: Jan 21, 2025
