adamboyd
Mar 12, 2016Explorer
tattoobob wrote:
http://www.renogy-store.com/100W-12V-Monocrystalline-Premium-Kit-p/kit-premium100d.htm
This is the system I'm thinking of getting once I get the cover off the TC I will see if I have room for 2 100w panels. I spend Friday thru Sunday on the beach and use the heat in the fall, and only have one battery I'm hoping this will help and I won't have to use the generator/truck to charge the battery
Remember those are not the new eclipse panels. Those are just regular 100w panels which are about 7 inches longer. It might not matter depending on the space you have, but you may be able to fit solar panels width wise instead of length wise. If so, you could put a lot more than 200w on.
44,060 PostsLatest Activity: Mar 28, 2026
